07-12-2009 09:45 AM
Hi there, i have the following question in regards to waveform generation with PXI-6552 card using HSDIO driver.
I have attached my VI in labview 7.1 version
The problem i am facing is that when i place a while loop for my entire function blocks, the waveforms that are generated occasionally change to logic '1' state before returning to the waveforms that i set.
The only reason i can think of is that my program keep initialising because my while loop is constantly looping the init generation block. I tried shifting the block outside of the while loop, but it gives a error.
I am able to get continuous waveforms when i dont use while loop or for loop.
But unfortunately, for my main program, i would need to use while loop or for loop as the arrays that i am using will be constantly changing.
A brief of my program, i am using scripting to plot out 9 different waveforms for 9 different channels. As the actual array i am going to use will change for every iteration, therefore i will need to use while loop to do it.
Hope i can get a reply soon.
Anyway i am using LAbview 7.1
Thanks to all!
Keith Tan
07-12-2009 11:24 PM
Sorry i realised what is my actual mistake, I have posted another thread. Please refer to this link http://forums.ni.com/ni/board/message?board.id=70&thread.id=11331
Keith Tan
