Digital I/O
VB 2005 & ContReadDigChan_ExtClk Example - Exception Error
Just got my 6503 and have played with the read and write to the card and now have hooked it to a device with an external clock.  When I select the example ContReadDigChan_ExtClk or any example with and external clock I get an exception Error.  I have put the clock input on different ports and have tried several things but still get the same error.  Is it me or is there a problem with VS 2005 and the Ext. Clock call?
I have set my Physical channel to Dev1/port1/line0:7
and my Clock Source to /Dev1/PFI0
The clock is wired to Port 0 line 0 and the data is coming in on Port 1.  The rest of the settings are at the default.  Any Suggestions?
Robert
(3,325 Views)
Greetings Robert,
The NI 6503 is not a correlated I/O card, meaning that digital measurements or digital generations are not performed on a clock. It is only a static digital input/output device. The supported timings for this device are On Demand or Handshake modes.  Each time a DAQmx Read or DAQmx Write is called, the read or write, respectively, will be perfomed.  There is no buffering or continuous acquisition of data with this device.
Hope that helps explain the error.  Please let me know if you have any additional questions...
Nicholas B, National Instruments
(3,306 Views)
