Digital I/O
Using an External Digital Trigger to Read Digital Input Once
I am using the NI USB X Series (specifically the NI USB-6343) and programming in Visual studio 2010 with C# .NET . What I have been trying to do is use an external Digital trigger on Port 1 (PFI0) and reading the input from Port 0. When there is a rising edge on the digital trigger line (PFI0) I want that trigger a read from the input port (port 0) just once next I want it to be retriggerable so it is ready for the next trigger again without the user needing to do anything (like press a button to start looking for the trigger again).
I tried creating my task, and using the configure trigger function on the same task, but my code doesn't seem to wait for a trigger it just reads the input data from port 0 regardless of whether there was a trigger or not.
Have I misunderstood how the trigger works? What am I missing?
Thank you and I appreciate the help.
(3,846 Views)
Have you tried including the triggering in the task in NI-MAX? This would be a good initial test to be sure that you are able to get a simple trigger case working.
If you have LabVIEW, try using the  "Voltage - Finite Input" example. This should be a good starting point for building your C# code.
Also, have you verified your trigger signal with a loop back test?
Matthew C
NI | AE
(3,741 Views)
Hello Matthew,
I have tried using MAX and configured a task to read Port 0, however I want to only read 1 sample when there is a trigger. The only option in which I can configure a trigger is: 1 sample (Hardware Timed) acquisition mode. However, when I run the program from MAX I get
Error -200077 occurred at DAQ Assistant
Possible Reasons:
Requested value is not a supported value for this property
Property: SampQuant.SampMode
You have requested: Hardware Timed Single Point
You can Select: Finite Samples, Continuous Samples
The only other 1 sample read is "on demand" which does not have the option to use a start trigger.
I wanted to try the N samples option, however it requires a minimum of 2 samples to work.
Is there any other way around this?
Mulan
(3,734 Views)
Hi Mulan,
USB devices like the USB 6343 are not able to use hardware timed single point sampling because the data transfer is non-deterministic.
Which devices can use Hardware-Timed Simple Point Sampling
Also, you're correct that on-demand sampling will not work with a trigger.
Without changing your hardware, you're remaining option would be to use finite sampling with 2 samples and then either store or throw away the extra sample.
Matthew C
NI | AE
(3,721 Views)
Have you considered configuring the task to use the PFI0 signal as an external sample clock?  It sounds to me like that's the kind of behavior you're after -- each active edge on PFI0 would cause one sample to be A/D converted instantly and stored in a buffer for later retrieval.
I only program LabVIEW though, so I'm no help on the C#.NET syntax.  I also don't think MAX allows you to configure an external signal as a sample clock.
-Kevin P
(3,705 Views)
Hi Kevin,
That does sound like what I am looking for, however you mentioned one sample will be read on each active edge. Do you mean both rising and falling edge, because I am looking to collect a sample on the falling edge. Is is possible to read data on the falling edge of a signal or only a rising edge?
Sincerely,
Mulan
(3,701 Views)
DAQmx Timing.vi lets you configure which edge is the "active" edge for sampling.  There's an input terminal you can right-click and create a constant (or control) to define which edge to use.
-Kevin P
(3,696 Views)
