Digital I/O
USB 6501 Lines Inverted
I am using the USB 6501 to write to ports 0,1 and 2 to control when LED's turn onUsing the test panel in Automation Explorer, I can reset the device and all lines are offWhen I run the VI, all lines turn on and the LED's turn off instead of on at the required timeHow can I save the configuration in Automation Explorer so I will have the lines inverted so all lines are off until required to turn onDo I need to create a taskI did try that but then got an error that indicated I cannot use the sames lines referenced in two places.
Thanks for the help,
Doug
(3,208 Views)
A reset of the device should make all of the lines inputs with (I believe) a pull-up on the line. Since you did not post your VI, no one has any idea of what you are doing differently.
(3,202 Views)
