From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
01-20-2010 05:39 PM
I understand USB 6008 has software-timed digital output, but I was wondering what the maximum output rate for a digital signal is?
01-20-2010 06:53 PM
01-21-2010 07:59 AM
Dennis is absolutely correct, because the USB-6008 only has software timed digital output, the speed of your output is completely dependent on the system. Even on one system, it will vary based on the programs you have running. If your virus scanner software decides to run a scan while you are acquiring, it could go from 150 Hz to 20 Hz pretty easily. The other danger here is that unless you are monitoring the digital signal with an analog input channel or through some other means, it would not be readily apparent that the output had changed rates. I would recommend a hardware timed USB device instead, such as the USB-6221. This will allow you to use a hardware clock for your generation, making it much more reliable.
