Digital I/O
Try to drive one digital only.
Hi
I have a PCI 6534 digital I/O card.  Is there a VI to drive a line individually instead of the whole port?  For example, I want to be able to drive the same pin in the DUT with two lines from two different port.  How can I switch between them without resetting other 7 lines?
Thanks.
(3,360 Views)
Hi bbtt,
In LabVIEW in the NI Example Finder (Help > Find Examples) there are a few different examples that can write a single line.
Once you have the Example Finder open, Browse to Hardware Input and Output > DAQmx > Digital Generation.  Write Dig Chan.vi demonstates how to write values to a digital channel.  Check out the Information listed on the right side of the example finder for a more in depth explanation.  The vi itself also has documentation on the block diagram.
Hope this helps!
Adam W
(3,346 Views)
