Digital I/O
Time taken by one 16 bit command using NI-8451 SPI from python?
I want to know how much will the time when the chip select will be low when I'm using 8451 to read data from a sensor via SPI through a python code. What is the maximum rate at which I can send command? I'm making a real time application so want to read data as fast as possible.
Message 1 of 1
(4,349 Views)
