Digital I/O
Suggest a hardware option
I have a AC power source which gives voltage & current in isolated channels. These channels will be connected to an digital energy meter.
I want to make or break the voltage supplied to the energy meter from my code.
It is a 3 phase voltage (R, Y, B) and neutral that needs to be controlled.
The max voltage will be 300V.
Pls suggest an appropriate hardware for this scenario.
Thanks in Advance
(3,979 Views)
Hi Ansar,
Thank you for contacting National Instruments.
You can find hardware for your requirement on the following link-
https://www.ni.com/en-us/shop/category/multifunction-io.html?productId=118688
Hope you have a pleasent day.
Kanchan Bhakoo
Applications Engineer | National Instruments
(3,963 Views)
