Digital I/O
Set-up for Micromanager
I am trying to send TTL signals with micromanager to control devices via NIDAQ USB-6008 .
The micromanager version is (Windows v1.4)
The NI 100X drivers are installed and are visible when adding  them to the hardware configuration of micromanager. (see screenshot)
However, There is a dialogue box that asks for some input: IOChannel value is undefined.
But apparently I should put some name here specific to USB-6008.
Does someone know what to put for the IOChannel name?
Thank you!
(2,469 Views)
Hello
I am using the same NIDAQ (6008) but with micromanager version 2.
I could call the device in micromanager, here is the info to set the device
device name: dev1  (check your USB 6008 dev number)
IOchannel name: dev1/port0
Hope this will help to call the device.
(2,311 Views)
