Digital I/O
Schottky Diode Network
Hello-
I am using the PCI-6534 board and I need to terminate it properly on my test/evaluation board that the NI-board will be communicating with. Can anyone recommend a good company to buy schottky diodes, either in single surface mount packages or entire diode networks (ie. 16 channels w/ 32 diodes). I know the data sheets recommend some companies, but CAMD no longer produces their diode network, and I am not finding anything on my searches. Thank you.
(3,457 Views)
I recommend using the Zetex SDA32N20 chip. This will give you the same functionality as the discontinued CAMD chip. The SDA32N20 diode array chip is available from Digikey as well as other chip vendors.
(3,457 Views)
Digi-Key doesn't have anymore in stock either. Do you have names for any other vendors that might have the chip? I am still having a hard time finding some. Thanks.
(3,457 Views)
