Digital I/O
SCXI-1001 not detected in NI-MAX
We have just upgraded to a newer PC running Windows 7 64-bit.
The old PC was Windows 2000.
The DAQ card NI PCI-6071E is detected in N(-MAX.
There are no errors in Device Manager.
NI-DAQmx 14.2 is installed.
The SCXI-1001 chassis is not detected in NI-MAX.
What else do I need to do?
(6,692 Views)
You just need to add the SCXI chassis manually. Please refer to Step 11 from the link below.
https://www.ni.com/docs/en-US/bundle/373236m/resource/373236m.pdf
MCOTO
(6,670 Views)
MCOTO
I was under the impression that NI-MAX should detect it automatically.
But I did follow the directions to add the SCXI chassis manually.
Yet there is a redX next to the icon and none of the modules are detected.
(6,666 Views)
Just wanted to add that not only does the SCXI-1001 chassis have to be added manually so does its modules.
The Auto-Detect button did not work.
(6,646 Views)
Were you able to properly add the modules to MAX and take some measurements?
MCOTO
(6,642 Views)
I was able to add the modules with no errors.
Have not tried running the LabVIEW program yet.
(6,618 Views)
