09-28-2020 08:35 AM
Hi everyone,
I have two questions regarding NI9401:
1. Is there a signal breakout board for NI9401 module (for separating channels from the d-sub connector) available for purchase, or we need to design our own breakout board?
2. Does anyone have experience using NI9401 to input to Power Integrations gate driver core?
I look forward to your reply, thanks!
09-28-2020 09:42 AM
@JustinZZJ wrote:
Hi everyone,
1. I see a recommendation for a NI-9924 terminal block.
2. My main concern would be the current needed for whatever device you are using. The NI-9401 is rated for a maximum output current (to maintain TTL levels) of 2mA.
09-28-2020 11:08 PM
Thank you so much! This is very helpful.
The datasheet for gate driver says the input bias current is 190 uA and turn-on threshold is 2.6 V. Do you think NI9401 is suitable? Is there anything else that I should pay attention to?
09-29-2020 05:53 AM
Sounds like you should be just fine.
09-29-2020 08:12 AM
Thank you!
