Digital I/O
Pulse train generation using NI 9403
Hi all,
I have to generate pulse trains using cDAQ 9178 and NI 9403 DIO module. I want to out pulse train on two lines (line 0 and line 1) after selecting lines on Front panel ( a boolean switch maybe). So far I have written a program to generate pulse train on single line. I am not able to reduce the period below 2 ms.
(1) How to output pulse trains on two lines (one at a time)? The line selection should be done on front panel. I used case structure but then even single channel won't output.
(2) Why do the cycle period limits at 2 ms? Is there some mistake in my code? I tried using wait(ms) function but same result.
Message 1 of 1
(2,837 Views)
