Digital I/O
NI Database corruption issue
This is regarding using the DAQMx SDK monitoring a digital IO board.   We have had on multiple occasions where the NI Database gets corrupted and has to be reset in NI-MAX.   We are supporting 24/7 monitoring for factory lines so this kind of problem is unacceptable.   Is there a way to programmatically reset the database if the error is detected?  Right now we are manually resetting the database in NI-MAX.
Thanks in advance
(1,216 Views)
(1,188 Views)
