Digital I/O
NI 9481 becomes unresponsive overnight
This is to control an environmental chamber. Feature I am having trouble with will allow for the user to set a time to have the chamber turn on in the morning, hence saving power. My problem is the program works fine, until the computer sits over night. When I come in the next day the temperature on the Watlow F4 has changed (this means the VI ran, should eliminate sleep/hibernate issues) but the relay did not close. This is running on a PC with Windows XP. I have posted the project. Comms with the Watlow are through a USB to Serial adapted, the 9481 is connected to a cDAQ 9171.
(5,386 Views)
Accepted by topic author NotanNIguru
Hi NotanNIguru, it seems like a memory leak in your program. What’s the memory size of your computer and what’s the OS?
There are a few changes you could make with your code:
  1. Check if you have closed references properly. Opening references repeatedly without closing them may cause a memory problem because each reference requires memory.
  2. There are a lot of coercion dots on your block diagrams. When you see a red dot appear by the input of a function, this means that the function is expecting one type of data, but receives another. LabVIEW converts these for you automatically, but it does have to create a buffer in memory to change the data type of the value. You can remedy this issue by right-clicking on the control or indicator on your front panel and selecting Representation and changing the representation to match the other data type going into the function.
There are a couple of articles talking how to improve LabVIEW performance:
Improving the Performance of Your LabVIEW Applications
Tips and Tricks to Improve LV Performance
Yupeng J.
(5,365 Views)
Are you using the 9481 to apply power to the chamber?
If so, what is the voltage and current requirements of the chamber?
-AK2DM
(5,362 Views)
I am not dirrectly powering the chamber, I am merely replicating the actions of the physical buttons to allow remote opperation.
I am passing 120VAC to a relay, the closure only needs to be made for a moment.
(5,347 Views)
This is running on Windows XP with 2G of Ram.
I did have a memory waterfall, I found after I posted so here is the update:
1) Good call. I was not closing the DAQmx properly, fixing that seems to have controlled the leak mostly...
2) Good Idea, I will look into this. There is still an increased memory allocation of about 10K every minute or so, the coersion might be the culprit.
I ran the program over the weekend (After DAQmx being properly closed) and still no trigger. I will update the representation of th inputs into functions and try again tonight.
Thank you for all your help.
(5,346 Views)
