Digital I/O
NI-9425 Clock Rate
I am currently attempting to change the clock rate on a NI-9425.  The module manual states that the rate should be 7us, but when I am testing it the rates seems to be locked down to 1kHz that is a far cry from the 140kHz that is defined on the speciifcation sheet.  Is there any method to change clock rate without using the FPGA module.
Message 1 of 12
(5,434 Views)
What are you using as the clock? The 9425 should be capable of a sampling rate of 140kHz as you're saying, if it's using a clock set to said rate, and if it's not limited by any attached hardware. What hardware do you have attached to the module?
Andrew B.
Andrew B.
Application Engineer
National Instruments.
http://www.ni.com/support
Message 2 of 12
(5,413 Views)
I have checked the clock on the associated hardware and it is correct.  When I attempt to set the clock using the clock icon I get an error about the device not being capable of operating in a buffered mode.
Message 3 of 12
(5,405 Views)
Could you send a screenshot of how you're attempting to implement this in your code.
Andrew B.
Andrew B.
Message 4 of 12
(5,401 Views)
I have attempted both methods shown below.  The first gives me the buffer failure.  The second does not give an error but maintains the 1kHz sample rate.
Message 5 of 12
(5,398 Views)
Have you tried explicitly wiring in a source to the sample clock timing function?
Andrew B.
Message 6 of 12
(5,372 Views)
How would I go about performing that?
Message 7 of 12
(5,370 Views)
As shown in this VI snippet. Create a control or constant from the source. Then select which clock source you're looking to reference.
Andrew B.
Message 8 of 12
(5,365 Views)
Sorry it took so long to reply got called off onto something else.  Using sample clock gives the same you cannot use buffered device error.
Message 9 of 12
(5,315 Views)
Could you attach your code, so I can try to replicate the issue on my end and debug from there.
Andrew B.
Message 10 of 12
(5,255 Views)
