Digital I/O
NI 9403 using FPGA as an input module help?
Hello
I just want to ask is there any examples for using Ni 9403 as a input module to
get the reading from encoder using FPGA module?
I want to get started with it. But the examples I found are for scan module?
Should I go in chassis properties and set is as FPGA module, will it work that
way for FPGA controller?
SaraN
(6,272 Views)
Hi Sara,
i am also trying to access NI9403 in FPGA mode. have u changed to fpga mode? can u c all modules?can u run any programs in this mode?
Samira
(6,137 Views)
its done!thanks
(6,134 Views)
well how is it done?  ;D
when running i face:
Error Code: -63040
NI-RIO:  (Hex 0xFFFF09C0) A connection could not be established to the specified remote device. Ensure that the device is on and accessible over the network, that NI-RIO software is installed, and that the RIO server is running and properly configured.
the device is on (power and act/link leds on) and software is also downloaded. can u help me with that plz?
cheers
Samira
(6,129 Views)
Hello AutonomusMode,
this is normal that no moduls are shown on a cRIO system in MAX.
You can see the moduls in your LV project explorer.
What LV Version is in use and in which VI the error happend?
Can you post your project?
Attached a little example project.
dublicate post on this web site
crio 9024-URGENT!
MAX
crio 9024 NI 9403
best regards
Alexander
(6,118 Views)
Hi Sara
can you tell me how to connect(circuit diagram) A Phase, B phase & Z Phase of encoder output to NI 9403 to measure the pulse count and direction from the connection. I am trying to use 2 channels in NI 9403 for A phase & B phase measurement.
thanks
(5,917 Views)
Hi Nitin
Although Sara may reply, it would be best for you to create a new thread since this one has been dormant for nearly six months.
Kind regards
Chris | Applications Engineer NIUK
(5,885 Views)
