Digital I/O
Initial state of PClk (PCI-DIO-32HS)
I want to use my PCI-DIO-32HS (6533) for 32 bit burst input with PCLK reversed.
But the board, according to manual, defaults to input and normal PCLK (output) at power up.
With the external hardware permanently attached (but not necessarily on!) will this not create a conflict ?
(Two output sources on the same PCLK line)
Or does the PCLK line power up 3-state and only go active (if still in normal operation) when a certain NI-DAQ instruction is called ? (Which by the way ?)
Message 1 of 1
(3,224 Views)
