Digital I/O
Initial Line Direction
I am quite new at LABVIEW environment, I have NI9403 Module which has 32 digital I/O s and implementing a LABVIEW FPGA project. I want to use these digital output pins as outputs and configured as "output" as follows:
However, still when I try to add these pins into the block diagram, it is recognized as "inputs" like:
So, am I missing some point, thank you very much in advance for anyone who can help.
(915 Views)
Can you try right clicking on it > Change to write to see if it works?
Romell Meléndez
Technical Support Engineer NI
(889 Views)
