05-06-2009 06:35 AM
05-06-2009 07:21 AM
05-06-2009 10:25 AM
05-06-2009 01:07 PM
05-06-2009 01:13 PM
May be someone have any ideas or Borland supported traditional libraryes for this device? (published on this site or converted does not works).
P.S. Sorry for bad English05-06-2009 02:01 PM
If you think the readings are incorrect, then you should be posting a question about that. Even if there was support with the old driver, that would not make a difference with the readings.
If you won't modify the old software to use either driver, then you will have to find an older device that is supported still by traditional DAQ.
