I need help determining what type of I/O card to buy.
I've contacted Hamamatsu Photonics and I am going to buy a photon-counting photomultiplier tube from them.
They told me to contact NI about which board I need to read the photon-counting signal.
The output from the PMT is, according to their literature, a TTL
positive logic.  It will be a stream of pulses that correspond to
photons measured by the detector.
I need to figure out what sort of I/O board I need to buy.  I need
something that can measure the TTL pulses, and will compatible with
Labview.  I need to use Labview to integrate the photon-count
signal with the control software for a monochromator that the detector
will be attached to.
I would appreciate any guidance in this matter
Chad
