07-06-2009 06:50 AM
hmmm...so in that case I should insert the webcam functions...my project...without thw initialization of the window part...I'll try it and I'll get back to you with the final solution! Hope it will work!
TNX!
07-06-2009 07:10 AM
Now it says that the blocks with the webcam ini and stuff are now good...
If those blocks were good in the original project ...why aren't them good now???
What driver do I need? I have the IMAQ...the run-time...and all the other stuff I need...
07-06-2009 07:24 AM
Hi snuk,
when did you get an error? With my vi's you can see the webcam image on the front panel, but not in the browser, rigth? Did you change to the PictureBox. If you do it, then the image should be displayed inside the picture box. If you get an error there, then maybe the typecast was wrong. Try it as shown in the attached image.
If you want to use IMAQ, then you have to download the IMAQ USB driver. It's independent from the vi's you currently use.
Mike
07-06-2009 07:30 AM
07-06-2009 07:41 AM
Hi snuk,
you should be able to see the webcam image in MAX. See the Grap.vi from the example finder. It should work similar with the USB Webcam.
Mike
07-06-2009 08:06 AM
I think I\ll give up...don't get LabView!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!111
I don't know what to insert in that video case to make labview read the usb and write the f%$T$$#$#ing image!
This should be for my project at the university...I've already made a site with a motion sensor screening in labview and all I have to do is get this signal from labview to make a video streaming...I HATE THESE PROJECTS! and they wouldn't let me use a ftp because they want it with labview...damn!
Anyway thanks for putting up with me! I'm sure u hate me for all the stupid questions!
07-06-2009 08:12 AM
Hi snuk,
this should work. Don't forget to close the WebCam after using it. If this don't work, then i can later make an example for you.
Mike
07-06-2009 08:19 AM
07-06-2009 08:30 AM
Hi snuk,
which three blocks do you mean? Which error did you get?
Can you upload your vi?
Mike
07-06-2009 08:38 AM
I can't even view an image in labview...why uploading it in html?
this error appears when I RUN the program!
