Digital I/O
How to use HSDIO to count rising edges of us pulses?
I am very new to HSDIO and am struggling at the moment to do what I am sure must be a very simple operation.
Currently using:
PXI-1031, PXI-8187, PXI-6552, Labview 7.1 Full Dev with RT module.
I have produced a vi which effectively triggers of a pulse and then counts the number of incoming pulses which arrive within several different timing gates. This works as I would like but for testing purposes I produced the pulses my self by pressing the button within the vi.
I now want to take this to the next stage and link this vi the the actual data pulse train that I will be measuring.  This pulse train will be a random series of ~0.5us pulses and could last indefinitely, i.e. >60mins. I have no need to physically record the pulses and save it at this present time but I need to be able to count each individual rising edge, effectively replacing my manual pressing of the button by the experimental pulse train generated by my apparatus.  However, I have no idea how to proceed with this.
Could anybody out there guide me as I am struggling to get to grips with HSDIO programming?
Many thanks in advance,
Nigel
Message Edited by Nige K on 06-14-2006 06:09 AM
(4,027 Views)
Nige,
How frequently do you expect the pulses to occur?  Rather, what the the shortest delay between consecutive pulses?
-Ryan
(4,007 Views)
The gate will range in length from 1 to 512 micro seconds in length and as the incoming pulse train is made up of 100ns long pulses which can appear at any pointin time, the minimum time between pulses could be of the order of ns!  If the pulses merge into one I would probably have to reject these (or just count as one) as there would be no way of determining how many real pulses there were.
I was thinking along the lines of reading the pulse at a high clock rate ~40MHz and then fetching a batch of samples which would be 1 microsecond in length. Once this is achieved I was hoping that it would be possible to determine i.e. count how many pulses there where in this 1 microsecond segment.  This would then be repeated until the user interupts the acquistion.
Coes any of this sound feasible?
Cheers
Nigel
(4,002 Views)
Nigel,
You could have used the multi-record feature of the HSDIO driver to count edges.  You could use the rising (or falling) edge of your pulse as a multi record advance trigger and use an attribute to determine how many records have been fetched.  In this fashion, you would be counting edges and ignoring the duration of the pulse.  However, there is a minimum amount of clock cycles for this trigger to rearm (~140samples) so at 100MHz, the rising (or falling) edges could not be closer to one another than ~1.4us.
Your method of just capturing the pulse train and post processing it is certainly valid.  There are certain caveats to this method in regards to streaming the data.  In order to capture more data than your memory can hold (as in very long acquisitions), you must be able to fetch data out of the memory faster than you're putting it in.  This can be done and benchmarked but is very system dependent as your are now pushing data across the PCI bus which is inherintly slower.  You can get better performance by using the "Data Width" attribute to be more efficient with your memory usage.
You could also use your gating signal as a Pause Trigger and capture only the pulses that occur when your gate signal is deasserted.  In this fashion, when your gate is asserting the Pause Trigger, the acquisition sessions stops putting data into memory.  When the gate deasserts Pause, the data then gets stored.  This will allow you to store only "qualified" data and give you better memory utilization.
Alternatively, NI HSDIO 1.4 introduced some new Hardware Compare features.  There is a white paper available for this new set of features (http://zone.ni.com/devzone/conceptd.nsf/webmain/15de80989fd122188625704d007885ea).  The feature that could be of use to you is the error count.  I would suggest using a Response mode without the stimulus.  This allows you to use an acquisition Pause Trigger as described above.  You would then generate "expected" data of L (for rising edge detection; H for a falling edge detector) on the channel to which is connected your pulse train.  When the data on your gate is 1 (NOT paused) and on your pulse train is 0, then there is no error,  When the pulse train transitions to 1, the hardware will generate an error.  If you turn on the "FilterRepeatedErrors" then the hardware will only store the first error of a consecutive set of errors allowing you to only register/count the first occurance (the edge) rather than the errors that occur in the duration of the pulse.  When the gate drops to 0, the comparison will pause so you will no longer count or record errors.  There is no rearm time required for this operation and will give you the best memory utilization and response time of the methods I've brought up so far.  This is a little trickier in that it is a departure from the "classical" digital applications but once you use the features a couple of times and read through the white paper it becomes second nature.
Please let us know if you have any questions
-Ryan M
Message Edited by Ryan M on 06-15-2006 09:51 AM
(3,986 Views)
