Digital I/O
How to reduce PXI-6509 crosstalk?
I have a PXI-6509 board in a PXIe-1073 chassis, with an RG1005050 cable.  I'm using the DIO pins exclusively for digital output.  I'm controlling the 6509 using DAQmx and MS Visual C++.
When I set certain bits high, I'm getting "glitches" or crosstalk with amplitude of 3-4 Volts and duration of 20-50 nanoseconds.  The crosstalk is triggering my Device Under Test (DUT) and my measurement (oscilloscope) at undesired times.  I'm wondering if there's a DAQmx setting to slow down the rise and fall times on digital outputs, and thus reduce the crosstalk.
Thanks for any help or suggestions!
(5,200 Views)
Ribbon cable is horrible for noisy situations.  But here are a couple of ideas to help:
1.  Make sure all of the DIO are either set to be output and unused are set to 0 or make sure the unused DIO are inputs with the signal grounded on your test board.
2.  Get a ferrite that is made to clamp onto a 50-pin ribbon cable.  They are just iron cores that go around the cable, but they act as a kind of filter.
(5,192 Views)
NI does sell a shielded cable for your device - http://sine.ni.com/nips/cds/view/modelpopup/p/pcat/918/lang/en
(5,186 Views)
Thank you both for your suggestions.  The ferrites didn't work, and a shielded cable wouldn't have been convenient, but you both got me thinking about the problem the right way.  I ended up debouncing the signal in downstream firmware.  I should have mentioned in my original post that firmware was available.
Kudos sent to both of you, and thanks again!
(4,955 Views)
