Digital I/O
How to Create Large number of pattern file(65536) automatically in Digital Pattern Editor
Dear community,I need creat  65536 pattern files(.digipat) to bust, but the files is so many, I can't creat one by one in manual, so I'm looking for some methords to  create Automatically. I find a way about Digital Pattern Compiler, but it's crash when I tried to open.
At present, I don't know how to solution, can you give me some advices? thanks.
(Remark: my English is not well, hope my words will not affect reading. I'm sorry!!)
Message 1 of 11
(3,499 Views)
But why 65536????
Are you trying to hardcode a specific value? like creating separate patterns for each possible value of a register?? you might want to look into using source patterns
Simple, no no no
Santhosh
Soliton Technologies
Message 2 of 11
(3,491 Views)
Dear santo_13:
thanks for your reply.
Why 65536??   Because I need make PXIe-6571 output so many times to verify my chips.
Yes, I'm now also trying to  encode by LabVIEW, but I don't know how to express the "INLDNL.digipat"(figure 1) in LabVIEW, what should I do to replace the VI "niDigital Load Pattern.vi"(figure 2)
Figure 1Figure 1Figure 2Figure 2
Message 3 of 11
(3,488 Views)
No no no no, you don't need to create separate patterns. The main feature of 6571 compared to HSDIO is the ability to have source and capture patterns.
Could you please explain what you're trying to achieve?
Looks like you're a beginner using 6571 and somebody tasked you with writing an ADC/DAC INL_DNL test and you don't know how to utilize the 6571 features effectively.
Santhosh
Message 4 of 11
(3,468 Views)
Yes, I'm a beginner using 6571.
My final purpose is try to control 6571 output 65536 times Continuously by write code in LabVIEW instead create 65536 .digipat files in Digital Pattern Editor.
Message 5 of 11
(3,462 Views)
Or how to program  could make data into 6571 so that can achieve like .digpat file
Message 6 of 11
(3,442 Views)
Please explain what you're trying to achieve, test method in specific and I will guide you appropriately.
As per your limited knowledge you want to replace the pattern load part, but that is not required. I believe you're writing some data to the DUT using SPI protocol and you want to write different or same data multiple times, for this use case you just need ONLY ONE pattern along with Source waveform.
This of the source waveform as a variable inside the pattern whose value can be written from software during runtime and allows you to reuse a pattern structure with a different set of values.
I would recommend you looking at the SPI register I/O example of digital pattern editor.
Take up this training - https://www.ni.com/en-us/shop/services/products/device-testing-with-digital-pattern-instruments-cour...
Santhosh
Message 7 of 11
(3,431 Views)
Dear Santo_13:
All you said is right, I want to writing some diffirent data to the DUT 65536 times by using SPI protocol to test DAC/ADC INL_DNL.
You said I just need ONLY ONE pattern along with Source waveform, I'm tring to acheive "the pattern whose value can be written from software during runtime", I'm really sorry I can't express my thoughts accurately in English.
The training of the link I will study carefully and also look forward  your guidance sincerely
Message 8 of 11
(3,419 Views)
Figure 1Figure 1Figure 2Figure 2Figure 3Figure 3Figure 4Figure 4Figure 5Figure 5Figure 6Figure 6Figure 7Figure 7
For example,the data bit width is 8. Figure 1 data is "0000 0000", Figure 2 data is "0000 0001", Figure 3 data is "0000 0010", Figure 4 data is "0000 0011", Figure 5 data is "1111 1101", Figure 6 data is "1111 1110", Figure 7 data is "1111 1111".
At present, I have to create 32678 patterns that will spend so much time. Now, dear Santo_13, I need your guidence to save time.
Looking forward to your reply and thank you very much
Message 9 of 11
(3,416 Views)
Accepted by topic author JCHe
First, I appreciate your willingness to learn.
It is simple (has quite a bunch of steps you need to understand), for this you will be using the source waveform feature of 657x, do the following,
  • Change the Data bits for D0-D7 to 'D' state and use source opcode
    • This tells the pattern that the digital state for these vectors will be dynamically defined by a source waveform
  • Create a source waveform by right-clicking on the project tree
  • Configure it with below values
    • This creates a source waveform configuration to be used along with the pattern. Here you define that each sample is 8bits long and it is MSB first when used in the pattern.
  • In the original pattern, in the first vector, add this opcode
    • This tells the pattern to use the data from 'register_write_data' source waveform for every call of 'source' opcode
  • Now on the programming part, you need to load this source waveform configuration into memory like you load a pattern
    • Implement this along with initialization part
    • To update the data in the pattern before burst
In short, imagine this source waveform as a form of variable used to store a set of digital states that you need to dynamically determine during the execution of your automation, so you need to define this variable (source waveform configuration as tdms file), write to this variable (write source waveform call), run the function that uses this variable (burst pattern(
Santhosh
Message 10 of 11
(3,399 Views)
