Digital I/O
How can I use digital I/O for a serial connection
I have the following problem. I need to capture/generate analog and digital signals. This also needs to be synchronized to the data captured from a UART on a serial connection. The problem is that all the data needs to have a common timestamp, i.e. the digital, analog and serial data must have the same timebase for comparison. Now, I know this is not possible with a 6036E because it only has static I/O lines. The M-seris has hardware-clocked digital lines, and I think I can set up sychronized analog/digital I/O operations using one sample clock. How would I synchronize this with the read serial data. My first thought was to implement a serial link using the clocked digital I/O on the M-series card. Does anyone have any idea how to do this?
Thanks.
(3,471 Views)
I am not to sure how you would setup the serial side of things, but the following example will get your along way in synchronizing your digital I/O and analog I/O on an M Series board.
Maybe if you describe your serial application a little more, I or someone else on the forum will be able to help out.
Anuj D.
(3,456 Views)
The aforementioned example:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=E4C68BB4D82A126DE034080020E74861&p_node=%20DZ52321&p_source=External
(3,454 Views)
