Digital I/O
FlexRIO 6581 Drive Capability
      From the datasheet of the 6851 card, the IO buffer performance should be that of TI SN74LVC8T245. However I'm seeing issues with the drive of this card doing a simple loopback test.
I have the Internal Card Supply 3.3V set up:
 e.g. DDCA Port0 is configured as Write and output port and write a clock out (010101..) on P0.0, I attach the breakout board (NI CB/SCB-2162) to the end of it and I can see the correct clocking data on a scope attached to the breakout board.
If I  have DDCA Port1 configured as Read and read data on P1.1 as soon as I connect P0.0 to P1.1 the clocking data out on P0.0 gets pulled down.
    From a hardware point of view the 6851 signal on P0.0 sees a load of the VHDCI cable in the first condition and the data out is fine with scope on the breakout board pin. Connecting P1.1 doubles this load, (i.e. adding a return through the cable to the 6851 P1) Should this increased oad be enough to pull the signal down?
(3,536 Views)
How are you getting on with this, are you still experiencing this issue?
If so, please can you clarifiy the final part of your post as I didn't completely follow what you were doing and what your question is:
"From a hardware point of view the 6851 signal on P0.0 sees a load of the VHDCI cable in the first condition and the data out is fine with scope on the breakout board pin. Connecting P1.1 doubles this load, (i.e. adding a return through the cable to the 6851 P1) Should this increased oad be enough to pull the signal down?"
If your question is regarding input impedance, I would recommend the following document: http://digital.ni.com/public.nsf/allkb/EAC887B71448E3478625772E0058D7D3?OpenDocument
(3,447 Views)
