Digital I/O
Error -2147220354 at nisyscfg.lvlib:Restart.vi:1680001
ok i have this crio connected on USB AN ETH, i can ping I can connect
on ni max say
software on the PC is
and the image is the same 2018
radutility goes
Model Model Code Serial Number MAC Address IP Address Host Name App Image Name App Image Version Time Result
cRIO-9057 79E0 023FF4AD 00:80:2F:41:7A:64 192.168.33.3 NI-cRIO-9057-023FF4AD CR304_ 4.5.0 0% Error -2147220354 at nisyscfg.lvlib:Restart.vi:1680001<APPEND>
<b>Complete call chain:</b>
rad_Deploy Image Wrapper_FB.vi:2760002
firewall is
setting on crio are
what to do?
there is no way to make it work
(866 Views)
I saw inconsistent IP settings in NI MAX.
Try "Inconsistent IP Settings" When Using a Real-Time Target in NI MAX
https://tmesystems.net/
(854 Views)
I set the IP address in static, the only other possibility is local only, but it is realtime...
i'll try that.
but it is stupid
(834 Views)
nope, it did not help
i am now on SERIAL connection
no reason for me to get any comunication problem, an so, still there no programming and  Inconsistend IP setting
(831 Views)
Updated to runtime 2025 q1 on the PC.
but same behaviour.
Is RAD utility compatible only to a certain point to on the CRIO OS?
do I need downgrade fot CRIO?
(672 Views)
