01-26-2010 08:57 AM
I have a special issues. I making a LabView Application from LabView2009. Using the setting for use on french Windows XP, I disable all other language (I try with all language too)
I create the Distribution Kit including only LV RT 2009, Advanced Signal Processing Toolkit and DAQmx 8.9.5 (because I use a USB-9211). I Select the Dialog Information language : French. I build the installer (0.98Gb; take around 15 minutes on a Intel Core2 Duo E7500 @2.93GHz, 3G of RAM)
After those step, I go on a brand new Windows XP (in French). Noting install. I transfer the Volume directory to the C drive
So. the installer will install :
95 packages will be installed.
Voilà! I got .NET Framework in Deutsh and a other one (asia I believe). I can remove the two .NET and everyting will still working. How I can remove those from the installer???
Thank
01-26-2010 09:10 AM
01-26-2010 09:26 AM
