Digital I/O
Digital I/O port by port (PCI-6503)
HI,
I tried to control stage by PCI-6503.
FYI, figure below shows pin connections.
18593i355196C5BDD7F78D
And, the two figures below show write and read cycle respectively.
Write Cycle.
18595i3EC9143D914E5441
Read Cycle.
18597iD72631AF015FFB45
And, I have a code for write and read cycle in the legacy function.
Important lines for writing cycle is
//initial configuration
status = DIG_Prt_Config(device, PORT_A, NOHANDSHAKE, INPUT);
status = DIG_Prt_Config(device, PORT_B, NOHANDSHAKE, INPUT);
status = DIG_Prt_Config(device, PORT_C, NOHANDSHAKE, OUTPUT);
//take R/W bar in port C high
CurrentState = 0x40;
status = DIG_Out_Port(device, PORT_C, CurrentState);
(Code for checking status through PORT_A is abbreviated)
//configure port A, B as output
status = DIG_Prt_Config(device, PORT_A, NOHANDSHAKE, OUTPUT);
status = DIG_Prt_Config(device, PORT_B, NOHANDSHAKE, OUTPUT);
//set address for LSB
CurrentState = 0x20;
//write data
status = DIG_Out_Port(device, PORT_A, (int)lobyte);
status = DIG_Out_Port(device, PORT_B, (int)hibyte);
// Take the STROBE line high to LATCH in the LSB data
CurrentState = CurrentState | 0x80;
//set address for MSB
CurrentState = 0x10;
//write data
// Take the STROBE line high to LATCH in the MSB data
In this code, DIG_Prt_Config is only called when the configuration need to be reset.
I tried to simulate this code in DAQmx, but in task approach it seems not simple.
I need to use DAQmx Create Channel VI and the DAQmx Start Task VI again and again whenever I write, because of the order of the writing.(see red part in code, writing on  PORT A,B,C, C, A,B, C, C...) In other words, I need to use (create channel VI, DAQmx start Task, DAQmx Digital Write, DAQmx clear task) sequence whenever the port I would write something on is changed. So, configuration (as I know, DAQmx Create Channel VI and the DAQmx Start Task VI sequence is equivalent with configuration) is needlessly called many times. And, I think it cause a problem on the performance, which is arisen from the property of 82C55 digital chip. About this issue, refer
-http://digital.ni.com/public.nsf/websearch/3E25A9780F2C48B986256120005AF098
-http://forums.ni.com/t5/Digital-I-O/PCI-6503-One-Port-In-One-Port-Out/m-p/119456
So, my question is how can I imitate the code above with DAQmx?
(3,757 Views)
To clarify, I'm attching one more figure. That's the part of what I write for imitate write cycle. And I confirmed that writing command to stage controller is not working. But reading something from stage controller is possible. So, I think there is no problem in the connection between stage controller and PCI 6503.
Please read from bottom to up.
18603i64393407D6D1A2EF
(3,755 Views)
Hi milistaff,
Try creating something like that attached example, where each stage has its own case in a case structure and the reference is passed around via shift registers to eliminate creating the channel and start task everytime.  Hopefully this helps!
h_baker
(3,706 Views)
