08-19-2020 08:53 AM
I am trying to measure a differential voltage across a FET, FET is operated at 48V but the differential voltage will be less than 1V.
Can I configure NI9205 as differential voltage measurement
08-20-2020 07:33 AM
Yes, it can work in differential or single-ended mode.
08-24-2020 03:35 PM
You would be violating the max spec for each AI channel by having a Common Mode of 48V.
