Digital I/O
Data Transfer b/w Target and host using DMA FIFO's
Dear NI,
     Am facing a problem while writing data into the DMA in the Host environment,
Steps i did:
1. Invoked the FIFO in the Host environment.
2.Connected it to the VI reference.
3.Configured the DMA Depth.
4.Started the FIFO.
5.An Array is initialised and adata is fed into Array using the File operations.
6.and the DMA is read in the Target VI.,
In the Above process, i attached a indicator to the DMA while reading in the Target environment,
but i could not observe any activity,
if some one tried please let me know the procedure to do the same,
am attaching the Host VI for reference
(3,367 Views)
Hi Kalyansuman,
Thanks for the post and I hope your well.
I am afraid you need to keep your posts in one place on the forums - this helps you support your issue effeciently.
I will post in the LabVIEW forum.
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,326 Views)
