Digital I/O
DIO singals
Where can I put DIO signals in a SCC-FT01 module and on a SC-2345 so I can controll it from Labview.
(3,381 Views)
Hello Tabby,
Thanks for your post!
I see that you are wanting to connect DIO signals using your SCC-FT01. If the module is currently in the same state that you purchased it in you cannot use it for DIO with out some modifications to the FT01. Please see the following Knowledge base that talks about how to customize your FT01 for DIO.
Using the SCC-FT01 Feed-Through/Breadboard Module for Custom Digital I/O Signal Conditioning in NI-D...
See the attached documents in the Knowledge Base that show how to remove the resistors for customization. Let us know if this helps you with your questions/concerns.
Cheers!
Corby_B
http://www.ni.com/support
(3,361 Views)
