Digital I/O
DAQmxFailed error code -2147220712 signification
Using the PCI-6528 card, we developped an application that was working fine and the discrete driver was able to read and write discrete. After a certain time, for no apparent reason, the application started having problem with the discrete card installation. We found a problem by logging messages using:
Error:
 if( DAQmxFailed(error) )
  DAQmxGetExtendedErrorInfo(errBuff,2048);
 if( taskHandle!=0 ) {
  // DAQmx Stop Code
  DAQmxStopTask(taskHandle);
  DAQmxClearTask(taskHandle);
 if( DAQmxFailed(error) ) {
  if(pml) pml->logMessage(1, "DAQmx Error from channelWrite ", "%s(%d): %s", __FILE__, __LINE__, errBuff);
  if(pml) pml->logMessage(1, "Error - 1st", "%s(%d): %d", __FILE__, __LINE__, error);
after each DAQmxReadDigitalLines or DAQmxWriteDigitalLines calls. The errBuff is empty and the error value is -2147220712. Could you please help me on the meaning of this return code?
Alex
(4,397 Views)
Hi Alex,
Thank you for posting to the NI forums.  It sounds like something has gone wrong at the driver level.  Repairing the driver and Measurement & Automation Explorer  (MAX) may help resolve this error.  If you are using Windows, open Control Panel >> Add Remove Programs >> National Instruments Software.  Select the driver and click Repair; do the same thing for MAX.
Please post back if you have further problems.  Thanks!
Ed W.
(4,382 Views)
