Digital I/O
DAQmx Write Error
What does "DAQmx Write (Digital 1D Bool NChan 1Samp 1Line).vi<append> (-200429)" mean?  I can't find the error code listed anywhere.
Thanks!
(3,307 Views)
If you have automatic error dialogs turned off, all you have to do is right click on the error out indicator and select 'Explain Error'. when you do this, you get: 'Value passed to the Task/Channels In control is an empty string (or I/O control).
The value must refer to a valid task or valid channels.'
(3,305 Views)
