Digital I/O
Control a USB-6525 using Python
I am trying to control a USB-6525 using Python.  I have downloaded and installed the latest version of NI-MAX.  I also installed PyDAQmx.   However, it seems that there is a dependency that is probably not installed since I have minimal NI Hardware / Software installed in my machine.
The error I get: " Location of niDAQmx library and include file unknown on win32 - if you find out, please let the PyDAQmx project know"
I serched and the error is generated because there niDAQmx.h file is not present.   I found the following post:  https://www.ni.com/en/support/documentation/supplemental/18/location-of-ansi-c-ni-daqmx-shipping-exa...
However, there I cannot find an installation to install this examples.  Is there a location or an installation I can use to install those examples?
(6,527 Views)
What do you mean you downloaded latest NI MAX version?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGQwCAO&l=en-US
I would suggest you downloading DAQmx lastest version in case you don't have it yet:
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
(6,450 Views)
Posting this in case it can help somebody with  a similar issue.
I had downloaded the latest version of NI-DAQmx.  However, after speaking with an NI support engineer.  It seems that that was the installer for only runtime version.
I was pointed to the NI-DAQmx installer for development.  Once that installation happen.  PyDAQmx runs quite well.
Rafael
(6,444 Views)
It was a pleasure, remember to Kudo the posts that are helpful and mark the posts as solutions to have an even better forum community!
(6,440 Views)
Hello.
I have searched for solutions where I can operate the USB-6525 with python. I guess I should need some kind of DLL-library. I was very surprised when the only thing is drivers at 1.8 Gb! Then is is not even obvious what I should install. Is there any easy to use DLL-library?
Kind regards
/Björn
(5,536 Views)
Hi Bjorn,
It looks as if this thread is pretty old. I would recommend creating a new thread with your question in order to receive more attention. In the meantime, please review the following link. Your answer may be found here.
https://www.ni.com/en/support/documentation/supplemental/16/python-resources-for-ni-hardware-and-sof...
Best of luck!
Austin
(5,520 Views)
