Digital I/O
Can I use DIO port of NI8451 as extra CS lines ?
 I have 30 slave devices to communicate, but the USB-NI8451 only have 8 CS line. I am thinking I can use the DIO port as extra CS lines.
Is that possible?
And then I can use two NI8451s to communicate with 30 slave devices .
(2,864 Views)
I do not recommand this method.
SPI is different from DIO which only has 1 and 0 signal.
You could have a better understanding of SPI Bus, DIO and I2C with below links.
https://www.ni.com/docs/en-US/bundle/virtual-bench-help/page/digital_io_toc.html
Understanding the SPI Bus with NI LabVIEW: https://www.ni.com/en/shop/labview/understanding-the-spi-bus-with-ni-labview.html
SPECIFICATIONS USB-8451 OEM:https://www.ni.com/docs/en-US/bundle/usb-8451-oem-specs/resource/290598a.pdf
Using I2C with LabVIEW and the USB-8451: https://www.ni.com/en/support/documentation/supplemental/21/using-i2c-with-labview-and-the-usb-8451....
(2,800 Views)
