Digital I/O
Camera Attribute Of GPIO
Dear All
I am using GigE camera and VBAI for vision inspection. If I am using one script its change the attribute of another script. How is this possible? Please share any document from where I can conclude and convince s my client.
Thank You.
(2,352 Views)
Camera attributes are either streamable or non streamable. Non Streamable attributes are only saved in the camera and not in the software configuration file.
This means that once a non streamable attribute is set in one VBAI inspection, a different inspection will use the latest value set.
Unfortunately, Vision Builder AI does not show you whether an attribute is streamable or not.
If a camera must be used in different inspections with different settings, we recommend that you call the Read/Write Attribute step in all the inspections that use the same camera, with the correct values for each application.
Hope this helps,
Christophe
(2,333 Views)
