Hi GB Charlie,
there are multiple ways of achieving what you want. Using a pattern would be a fancy way of doing this, scripting should work as well (depending on your the device you are using). For generation frequency, you have to either use a fraction of the internal clock (e.g. 50Mhz/25Mhz/12.5MHz/...) or an external one.
Hope this helps a little bit
Oli
