Digital I/O
6221 digital outputs synchronization
Hi
my problem is rather trivial but I cannot find a working solution.
I am using a 6621 card and I want to produce 4 digital signals from it:
-a digital clock of 10 Mhz (the value is indicative
-a bit pattern on the three remaining lines. The bits should be synchronized to the clock.
I managed to produce the signals independently, but they appear to be out of sync: the bits move randomly with respect to the clock.
I tried to study this and this pages, but so far I had no luck to have everything working properly.
Any hint or suggestion would be greately appreciated.
Thanks.
Paolo
(3,499 Views)
Hi Paolo,
I think that the solution for your problem is to share the clock of your digital channel. I suggest to you to see the screenshot below: remeber to select "Digital output" in the create channel VI and to arrange the entire VI as you like.
Ciao!
______________________
Simone S.
Academic Field Engineer - Med Region
(3,482 Views)
Ciao Simone,
thanks a lot for the quick reply and for the example. I started from that and finally managed to have my VI working.
Cheers,
Paolo
(3,479 Views)
