**Note: This tool is now an open-source project available on a bitbucket repository so everyone can contribute to features and bug fixes. You can join the project and/or download the updated VI Package for LabVIEW 2016+ here:
https://bitbucket.org/merecsengineering/vi-properties-editor
When you find any bugs or you want to have some new features, everyone can add this on the Bitbucket "Issues" page.
This VI Properties Editor can be used to edit the VI Description, Help Tag, Help Path, and Name/Description/Tip for Controls & Indicators from a single window.
Requirements
Installation
To install the VI Properties Editor package, you will first need to install VI Package Manager (VIPM) from JKI. Once VIPM has been installed, simply download the attached .vip file below, double-click, and follow on-screen instructions to complete the install.
Once the install through VI Package Manager is complete, restart LabVIEW to refresh the menu options.
How-to
Limitations & Known Issues
Support
Please post a comment below to report an issue and I will add it to the list of known issues (or fix it and add it to a list of 'Bug Fixes').
Hey Robert,
When I attempt to install this, I get the following error in VIPM:
"This package is not compatible with your operating system or any LabVIEW version installed on your computer".
I'm using Win7 Pro 64bit and LabVIEW 2010 SP1.
Thanks for your help,
Mike
Mike,
Are you using LabVIEW 2010 64-bit or 32-bit? I just installed it on 2010 SP1 32-bit and it worked with no problem at all.
David
So here's a wierd thing, when I double click it, I get the error message as above, but when I open the package from within VIPM, it works fine.
Anyway, the main this is that it works now. Thanks for the sanity check.
Are you double-clicking from a shared network drive and are you using an old verison of VIPM?
Michael,
Just posted this on JKI forums as well:
http://forums.jki.net/topic/1700-error-when-opening-vip-files-directly-from-windows
We can continue there if you prefer, but to answer your question, yes (on a network drive) and yes (2010).
This is pretty nice. There are two things I'd like to see changed to make it even more useful:
Any chance of releasing a version of this (and the VI to XML Documentation Tool) for 2009? I lot of my code still needs to support that environment.
I updated the package to support LabVIEW 2009, have at it!
Thanks Robert!
Quick bug report--I forgot to check out some files from source control, so they were locked. There is no error message, so I ended up losing about 30 minutes of work that could have been resolved by a simple right click . I fixed it on my version but I hope nobody else runs into the same problem.
Other than that this is a pretty amazing tool. Thanks!
Hey folks. Would it be helpfull to add something like this to the package build process from within VIPM?
We have a post-build hook that creates and binds documentation to our packages - if VIPM did that for us, that'd be super.
Hey Chris. Contact me offline with the details.
Great tool, very useful !
Just 3 comments :
- when working on medium and large projects, it takes a long time to load and then save all VIs ... (about 2 minutes to load or save 500 VIs !!)
- it misses a button to load VIs when you need, instead of only at startup
- Not possible to (easily) add a carriage return on VI documentation, because there is toggle on "apply" button with enter key
I fixed these points on my own version... but I can't see how to share it ? Please, contact me if you're interested to get it and build a new vip...
Thanks a lot !
Thanks for the update! If you want me to post your package on this doc, I'd be happy to add it - send it over to robert.des.rosier@ni.com.
Added the update from Saphir in v14 - thanks!
It would be great if VIPM would do this. I have a post-build hook that adds at the bottom of all the VIs in a package the package name and version number, so when developers are using Ctrl+H they can quickly see what version they have without having to go to VIPM to double check.
Fabiola. That's a great idea!
i second fabiola's idea!
To the VIPM Idea Exchange!
Great minds think a like... sorry for hijacking this thread... I posted the idea here: http://ideas.jki.net/topic/397188-/
After a control label is updated on a VI via the MC Listbox, the image in the picture control isn't updated for the new label.
Loving the tool though!
Creat and usfull tool -> just one issue we run into:
ni_labs_lib_vi_properties_editor-1.0.0.15.vip (144.8 K) -> is build for LabVIEW 2013 SP1 + If your System is LabVIEW 2013 or older you have to yous ....14 or older.
Thanks for that usfull tool!
Have you seen how many hoops you have to jump through to get something published there?! This will never pass muster.
Christian,
I downlaoded the package a published a copy to our internal VI Package Repository so our entire team has visibility and can install it quickly. And, by adding it to our repository it is listed next to all of our other VI Packages when sorting bym the Repository column in VIPM.
Just thought I'd share my work around.
I agree with david regarding the requirements to publish on the toolsnetwork. ;o(
James
Guess it depends on whether he thinks this is a good representation of the quality of software to be found on LVTN, then.
We are working to prep a number of LVTN products for NIWeek releases, but maybe after NIWeek one of us can run through a review for this tool and post it to the repo…we will likely not create a model page for it and would treat it like a number of the NI Labs/Systems Engineering libraries we host on the repo.
-R
Reply-To: "ni-966180868-2q9-2x-xx3@community-mail.ni.com<mailto:ni-966180868-2q9-2x-xx3@community-mail.ni.com>"
Date: Monday, July 6, 2015 at 9:50 AM
To: Robert Des Rosier
Subject: Re: - VI Properties Editor
Community<https://decibel.ni.com/content/index.jspa>
new comment by David Staab<https://decibel.ni.com/content/people/David_Staab> View all comments on this document<https://decibel.ni.com/content/docs/DOC-17043#comment-43959
Good idea! Can I host "Staab Labs" libraries on LVTN without meeting all the requirements, too?
Bring it! Just make sure you meet the LVTN requirements like the Systems Engineers and other community contributors have done:
https://decibel.ni.com/content/docs/DOC-8981
I’ll do the same.
See y’all at the LAVA BBQ!
-R
Reply-To: "ni-966180868-2q9-2x-xx5@community-mail.ni.com<mailto:ni-966180868-2q9-2x-xx5@community-mail.ni.com>"
Date: Monday, July 6, 2015 at 11:01 AM
new comment by David Staab<https://decibel.ni.com/content/people/David_Staab> View all comments on this document<https://decibel.ni.com/content/docs/DOC-17043#comment-43961
I need help, openning the package file in VIPM it tells me that it's "not compatible with any version of LabVIEW installed on this computer". I have LabVIEW 2011 and 2014, both 64 bit, and VIPM 2012.
Hello Charles,
Try to update VIPM to a newer version. I think version 2014 should help.
Thanks! Problem is that I can't upgrade VIPM to a newer version because I need pro edition and didn't renew my VIPM licence yet, so I'm stuck with version 2012...
Hey Charles, did you try one of the older package files included above?
-R
I did some improvements and also found a bug.
Improvements:
NEW: Save only VIs, which properties has been changed. LV 2013 Code can be found here. (In this version I also fixed the bug)
The bug description:
Bug found using ni_labs_lib_vi_properties_editor-1.0.0.15.vip:
I have accidently named a *.ctl as *.vi. Now in the "Properties Editor" the following happens:
Now we have an empty listbox entry and to the "DataSet Array" we add just "Invalid VI Type"
When I apply my changes and we are indexing this entry we
1) get an empty path,
2) get an open VI error and
3) all following VIs will not be saved because of the shift register and also
4) you don't get any error message
After talking with RDR we now improved the VI properties editor, added some new features and created a bitbucket (like github) repository so that everyone can join this project.
You can also download a new VIP from this site. (>LV2016 atm needed)
