Developer Center Resources
Calling .NET Assemblies from LabVIEW
» Calling External Code » .NET Assemblies
Overview
LabVIEW gives you the ability to use .NET Assemblies through several .NET nodes. Using these nodes, you can instantiate .NET objects, invoke functions and access properties of .NET classes and objects. In addition, you can host .NET UI Controls on the LabVIEW front panel.
To Instantiate a .NET Object
Use the .NET Constructor Node (Functions Palette » Connectivity » .NET » Constructor Node).
Also, use the Close Reference VI (Functions Palette » Connectivity » .NET » Close Reference) to destroy an object you have created.
For details, refer to:
Instantiating .NET Objects from LabVIEW
To Call a Method on a .NET Class / Object
Use the Invoke Node (.NET) (Functions Palette » Connectivity » .NET » Invoke Node).
Calling Methods and Accessing Properties of a .NET Class / Object
To Access a Property on a .NET Class / Object
Use the Property Node (.NET) (Functions Palette » Connectivity » .NET » Property Node).
To Host/Embed a .NET Control on the LabVIEW Front Panel
Use the .NET Container (Controls Palette » .NET & ActiveX » .NET Container).
Embedding/Hosting .NET UI Controls on a LabVIEW Front Panel
To Register for an Event of a .NET Object:
Use the Register Event Callback VI (Functions Palette » Connectivity » .NET » Register Event Callback).
Register Callback VIs for .NET Events in LabVIEW
Examples & References
The following examples install with LabVIEW:
Calculator VI: labview\examples\comm\dotnet\Calculator.llb
SimpleTaskMonitor VI: labview\examples\comm\dotnet\SimpleTaskMonitor.llb
Community Example: Calling .NET Assemblies from LabVIEW
LabVIEW Help: .NET Functions
KnowledgeBase 4IH72U6S: How LabVIEW Locates .NET Assemblies
Child Documents
Jervin Justin
NI TestStand Product Manager
