Developer Center Discussions
Read element of a 2D Array from Cluster
i must improve a VI that i s able to read a generic cluster in input and convert its elements in something of readable.
this cluster contains other element as boolean constant, boolean control, text string, dbl constant....
I need to read cluster and write all the elemet inside a document (text or something readable from an operator), as a report.
i try to follow the example of help desk of labview 8.6 NI_Example\foundamental\Array_and_Cluster\Flattened_String_to_Variant.
it's a nice example, but there is a problem with the 2D Array: the vi is able to write only the dimension of  2D array, while i need to write all the element of 2D array.  I search some controls to improve this function, but i failed.
So,  i'm waiting your help.
thanks,
Nicola
(5,567 Views)
Hi Nicola -
I'm not quite sure I understand your data structure. Do you have a 1-D array of clusters, and these clusters contain 2-D arrays (among other elements)? And you would like to able to convert this data structure to a variant, correct?
Chris Bolin
LabVIEW Partner Program, CLA
(3,906 Views)
