09-13-2010 10:04 PM
Anybody up for another discussion on our collective love/hate relationship with SV's and NI's PSP.
Has LV2010 lived up to your expectations?
09-16-2010 08:32 AM
I'm in! Using the new purple dots on an application right now. Additionally using the tag API and DSC for another application. My experience is that the NI PSP SV's work very well, once they have been configured correctly. The learning curve was a little steeper than I would have preferred. I'm also using the IO SVs on RT and the Scan Engine. I have a dynamic environment in which the name, metadata, number and everything about and IO point can change for each test. The one glaringly missing feature is the ability to easily convert a string to the appropriate SV.
As we continue this discussion, do you propose a thread here or an online meeting?
N
09-16-2010 09:05 AM
Hi Nancy,
Thanks for chiming in. I am not really sure where the best location would
be for this discussion. I initially choose ALARM in the hopes that some of
our SV veterans like yourself would
be interested to continue the previous discussion on the subject. I have
been knee - waist deep in LV2010 for a solid month now and have come across
quite a few confounding issues in regards to NSV's and would very much like
to compare notes with others. I also have created a 'dynamic' environment
where I can reconfigure my cRIO environment during runtime and do alot with
the SV and PSP API. What do you mean about the missing feature to convert a
string to the appropriate SV? This sounds like something I do quite a bit
when building NSV URL's.
09-16-2010 09:47 AM
Thanks Mike,
I'll be interested in feedback and any discussion as well, and can hopefully provide more NI insights and behind the scenes information where necessary.
I did a session on Alliance Day looking at dynamic use of SVs, but focused on LV 2009. I haven't had much time to work with these features in LV 2010 yet, but can test out anything you'd like.
Christian
09-16-2010 05:03 PM
Mike, feel free to buzz me anytime 303-359-4356. But in interest of keeping the discussion open for others:
Like I said, I'll send some screenshots this weekend.
Mike, are you running into any specific issues right now?
09-29-2010 09:31 AM
Here are some issues I have found recently...
1. Setting the RT system time to 00:00:00 at the very beginning of your app can hose up the SVE and create weird interactions between static NSV initialization and the use of the SV API.
I wish I could submit an example but I was not able to recreate it other than in a large app. Just trust me...don't do it!
2. I have found that the SVE, over repeated 'soft re-starts' of an RT app, can accumulate stale transaction references that can add significant cpu burden. In my case I often see 7-8%
increased loading upon subsequent restarts of my rt app. HW resets and SV deployment always fixes the problem until the next software restart. I am still working to create a small scale example of this phenomenon. Just putting it out there to see if anyone else has seen anything like this.
3. NSV and IOV urls have changed from LV2009->LV2010 in that you are now REQUIRED to prepend the string 'ni.var.psp:' or 'ni.var.io:' to all URL's. Previously you could get away without doing this.
Some other thoughts:
1. What happened to the promise of being able to programmatically deploy SV's in an RT app in LV 2010?
2. Why can't we have native LV SV events? It appears that the SVE natively supports this, could we roll our own?
