invalid file format error
Ok.. So I Downloaded dqmh_6.0.vipc and selected apply configuration and it seems that everything is fine, but nothing happens then.
What should I see or do now?
Roey
Message 11 of 17
(1,946 Views)
Well, if the VI Package configuration was applied without error messages, everything should be fine and you should be able to work with DQMH now 🙂
If you still run into problems, you can either reach out to JKI through one of the links I posted before for help with VIPM, or you can contact one of the DQMH Trusted Advisors for support. The list of DQMH Trusted Advisors is available on dqmh.org.
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
Message 12 of 17
(1,941 Views)
Actually I don't see that the problem was solved.. I don't see DQMH template or pallate in my LabVIEW.
In addition, when I select "Apply Configuration" I see a list of actions that VIPM should perform and all the packages there are checked to be installed, but when I select 'Continue' nothing happens..
Roey
Message 13 of 17
(1,925 Views)
Hey Roey,
As far as I understand, the issue seems related to VIPM. The best thing to do is probably to record a short video of what you are doing to see if we are not missing something and then post a support request on the JKI forum.
Olivier
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
Message 14 of 17
(1,898 Views)
I also feel that this is a vipm issue. I posted in their forum but it seems that there isn't a lot of activity there...
I'm not sure I can send a video record but maybe I can send some print screens if it helps..
Anyway, Thank you for your help. I hope that someone will find a solution for this error..
Roey
Message 15 of 17
(1,870 Views)
I posted also to vipm forum but it seems that there is not a lot of activity there..
I am not sure that I can send a video record but maybe I can share some print screens if it may help to recognize and solve the problem.
Thank you,
Roey
Message 16 of 17
(1,879 Views)
Accepted by topic author roey_p
Ok.. So the problem was solved!
I realized that during my copy and paste process the file was damaged. So I found another way to transfer the file and everything is OK now.
thank you all for your help, and now I 'only' have to study how to use the DQMH framework 🙂
Roey
Message 17 of 17
(1,842 Views)
