DQMH and Classes
Is there a good document/video on how to use classes with DQMH modules? I saw the quick tip #5 video but it's just surfing (very very fast!) the tip of the wave. Ideally a simple example project would be helpfull for many of us. I'm developping an application where a selected test is loaded in a subpanel. Typically I would use a plugin architecture where a test interface class that is overidden by a specific selected test class. I was planning to use a DQMH modules for each test but I have no idea how a DQMH module can be loaded dynamically.
Thanks!
Ben64
(3,924 Views)
Not regarding classes, BUT: For an example implementation of how to load DQMH modules dynamically, you can take a look at our HSE Windows Application Template, and especially at the startup.vi which uses call by reference nodes to dynamically execute the Start Module.vi...
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
(3,902 Views)
And this time, regarding classes! 🙂
1) Check out Wired-in's presentation at VIWeek 2020 here: https://www.youtube.com/watch?v=Q8Tte_rntNU.  I talk about using classes for the purpose of a hardware abstraction layer.  I give a few demos on it, so you get to see how I've structured the class hierarchy and used it in the DQMH module.  Might not be comprehensive, but it would be a good start.
2) There is also a good blog article on how to use classes within a DQMH module on the Delacor website: https://delacor.com/hal-in-your-dqmh-2/ .  Truth be told, I used this as my foundation for the aforementioned presentation!
3) Check out Tom McQuillan's VIWeek 2020 presentation here: https://www.youtube.com/watch?v=1aMsftXMlTY.  He spends a segment talking about how he does DQMH, and uses classes.
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
(3,896 Views)
Thanks Joerg and Christopher, I will have a look at the posted links (and maybe come back later with a few questions!).
Ben
(3,867 Views)
