DQMH + State machine
does this make sense?
I have 12 DQMH cloneables that are running when a user presses "start test". The test sequence is very sequential where its just write a message, read a message, decode a message, pass/fail based on decoded message etc.
I was thinking of having the EHL handle the public requests to start,stop,pause, abort test etc. The MHL would then wake up a state machine loop which is sitting below by sending a user event to wake up. The state machine would just run through its sequential steps over and over until a fail or time expires. I was thinking of putting a JKI state machine below the MHL.
Right now I have 5 loops which are EHL, MHL, Write command helper loop, Read helper loop, decode helper loop. They are running somewhat asynchronously.
(3,172 Views)
Accepted by topic author PatrickMiller
Yes, that makes sense. I've done something very similar, the MHL wakes up a helper loop to start a state machine. In my case it was a Simple State Machine, but otherwise the same as your scenario.
(3,167 Views)
Thank you this worked and solved some of my issues.
(3,106 Views)
