EDIT: We now have a place for you to post DQMH Feature requests here:
https://forums.ni.com/t5/DQMH-Feature-Requests/idb-p/delacor-ideas?profile.language=en
Hello everyone,
We have been getting DQMH feature requests via this forum, via conversations during NI events and direct e-mail. We keep track of every suggestion in our internal tracking system, but we thought it would be a good idea to have a central location for others to add their own requests. Please create a different discussion for people to discuss your feature request and point to that entry in your post here.
We will add some of the ones we have already received. If you find a feature request you agree we should implement, please vote by clicking on the "Kudos" button for that post. Also, our CCFO (Cheap Chief Financial Officer) has asked us to add the following: "If you consider a feature to be particularly important, be sure to mail in your vote written on the back of a new US$100 bill. Multiple votes are, of course, allowed and encouraged"
The more votes we receive for a particularly important feature, the more likely we are to implement it!
The Delacor team
Current feature requests:
Add a Rename Event utility to the Tools>>Delacor>>DQMH menu
Status: Done. Implemented in DQMH 3.0
Add a code to cloneable modules to make them behave as singletons
Add by default an error cluster in the Reply argument for Request & Wait for Reply Request Events
Add Request events to TestStand insertion palette if TestStand is installed
Status: Won't implement.
Support DQMH Modules Templates when creating a new DQMH Module
in DQMH 4.0 added the option for these templates for them not have to be installed in the LabVIEW Data folder, instead, the metadata file can include a full path instead of a relative path.
Discussion: DQMH first experience and a bit of a feature request
Add support for Real-Time or create a new DQMH module/project that would work on Real Time Targets
Status: Done. Implemented in DQMH 4.0
Discussion: Any caveats in using DQMH on Real Time
Module initialization with input from creator via Start Module
Remove the need for an argument when creating a new event
Status: Won't implement Implemented option to not have to add arguments in DQMH 3.0
Discussion: No arguments discussion
A way for the creator of a module to provide parameters for the Message Handler Initialize case
Status: Done. DQMH 2.1, we added a "code needed" bookmark with instructions inside Start Module.vi, so the developers would know where these initialization arguments if they needed to.
Discussion: Module initialization from Start Module and other ideas
A way to name modules/module clones during creation and then address them by name instead of by Module ID
Status: Wish List
Requests with a To/From/Reply To header
Status: Wish List
Floating Dialog Box for the Delacor Tools
Status: Wish List
Discussion: No discussion, the suggestion by K.Ross found further down in the comments to this document. If you want to discuss it further, feel free to start a new discussion.
Folder Cleanup
Status: Wish List
Discussion: No discussion, the suggestion by mRadziwon found further down in the comments in this document. If you want to discuss it further, feel free to start a new discussion.
Separate VI residing in each of DQMH_MESSAGE_CASES.
Status: Won't Implement
Move sequence structure in Request and wait for reply to have access to merge errors
Status: Won't implement. The majority of DQMH developers remove the sequence structure anyway. It is there to facilitate scripting.
Add the ability to choose the Icon Editor, currently only the default works. (I use Mark Balla's Icon editor.)
Discussion: No discussion, the suggestion by jdebuhr found further down in the comments in this document. If you want to discuss it further, feel free to start a new discussion.
Scripting API
Status: Wish List
Discussion: Scripting API
Combining the functionality of all 3 event types of DQMH
Status: Wish List
Discussion: suggestion by Barney10 found further down in the comments in this document. Also discussion available via Combining the functionality of all 3 event types of DQMH
The Singleton would stay as is, since it is the easiest way to introduce LabVIEW developers to the DQMH.
While working on code for a project that was using LabVIEW And TestStand, we ended up using Request & Wait for Reply events exclusively, this means that if the error is not part of the Reply argument and it is only sent to the error case and there is no one to listen to the error broadcast... calling code doesn't know that there was an error in the code called as part of the request.
Suggestion: Add Error cluster as part of the Reply argument by default.
Script wiring the bundle by name with the error going into the send notification and add a note indicating to developer to wire any errors generated by their code there.
Script unbundling the error from the reply on the Request and Wait for Reply API VI and merge it with any other errors and return it to the caller.
If creating a new DQMH module AND TestStand is installed we could create a new insertion palette item representing the DQMH module with sub palette items for each request (and request + wait)
Creating new request (and request + reply) events would add them also to the particular DQMH palette item.
The events could then be dropped directly into the sequence.
The Physical files would reside wherever they were created and simply referenced by the palette definition file (it's an ini file)
We can also specify that when dropping a Start Module.vi from the palette we also drop Synch Module Events.vi at the same time.
Discussion: https://decibel.ni.com/content/message/110465#110465
Add option to Tools>>Delacor>>DQMH>>Create DQMH Module from Template…
We would have a folder where DQMH Module templates could be saved and the tool would duplicate them, add them to the project and replace any "module name" mention with the "new instance name" provided by the developer.
Discussion:
https://decibel.ni.com/content/message/128227#128227
https://decibel.ni.com/content/message/137031#137031
We have received several requests to provide a DQMH Module template that would work on RT.
Discussion: https://decibel.ni.com/content/message/130068#130068
Remove the requirement to add an argument to the Argument window when creating an event. If no argument is provided, then the scripting would create the argument with a typedef that has a "dummy" boolean in its cluster.
Discussion: https://decibel.ni.com/content/message/130979#130979
Mads' request:
1. A way for the creator of a module to provide parameters for the Message Handler Initialize case. The Start Module.vi currently only sets the Module Admin input of the module. The creation of this VI could be scripted to include whatever parameters the initialization would need (the same way we do for requests now). I guess the current way to do this is to create a separate initialization event and issue that after creation, but this would then not run until after the initialization has been done...
For DQMH 2.1, a "code needed" bookmark with instructions was added to Start Module.vi, so the developers would know where to add this initialization arguments if they needed to.
Mads' request
"A way to name modules/module clones during creation and then address them by name instead of by Module ID (Currently the creator(s) of modules woudl need to administrate a linked list here outside the DQMH framework...or we have to request every module for their identity and/or broadcast a message with a target name in it)."
Mads' request
"Requests with a To/From/ReplyTo header: This one is a bit less general, but anyway: In one of my current use cases, modules might a) use a lot of time before the Message Handling Loop is able to process a request (it is doing time consuming work)...and b) the sender of the request might not necessarily be the one needing the reply. It would be cool to be able to issue a request to a module saying "take you time" - whenever you have finished handling this message (very long or even infinite timeout), send the reply to this given queue. (I would use queue here instead of notifier.) Here it would also be nice to just specify the target (queue) by name. That way the code issuing the request only needs to know the name (address) of the intended target (queue), not generate and supply a queue reference.
(multiple modules in one module lvlib, sharing the same events)
It would be very useful to have (full) support for having multiple main-VIs in (clonable) modules, and choose which type of the (sub)modules to start. All submodules otherwise share the same events/API. This is currently possible by manually adding copies of the main-VI, and manually modifying the start function, but when you add events they will only be scripted into the original main VI.
The module tester generated by the framework is designed to use front panel events to handle its front panel controls, this makes the controls unresponsive on real-time targets (which only support such events on targets with GUI capability). It would be nice if the template for the tester either used classical control polling instead to avoid the issue in general, or if there was a "to be used on real-time" option added to the module wizard that produced a no-front panel events version.
In its most basic version there are not that many of the controls that are supported anyway on RT, opening/closing panels for example, but the select module button is still nice to have working...and as a template it would be good to have it guide you to a working design for RT for any additional front panel controls you might add to the tester when you add user events etc.
Floating Dialog Box for Delacor Tools
It would be great to have a floating window that provided faster access to the Delacor Tools. I find it a bit clunky having to navigate through the menu every time I want to create an event. Especially in the scenarios where I have designed my module and I just want to build it up fast.
My suggestion is to have a floating window going from this (below)
to this (below)
But having it available from the menu and/or the floating window.
Sorry if this is already a feature and I have just missed it.
Kev
Folder Cleanup
Currently all vis and typedefs are just thrown in one folder. It makes it difficult for a TestStand developer to find a particular request he is interested in. I suggest a cleanup in folder structure on the hard drive to reflect the one of the library.
As your style guide suggest most cases commands are atomic and realized within one case. However, constrained space in each case makes it hard to accommodate more complicated code. There are two solutions - or to pack it to a subvi, or to expand the case structure and make it look ugly.
The first solution allows for neat hierarchy and even possible reuse for compound steps.
Such a vi could have Event Argument and Data Cluster clusters as input, and Data Cluster and CreateNest (Reply Payload) //if applicable//. Also it could automatically connect its error cluster to merge errors of particular case.
By default, if the event type of an event is "Request and wait for reply" the merge errors node DQMH_MESSAGE_CASES is placed exactly on the border of flat sequence structure. It renderd merge errors node unavailable , before it, or the flat sequence, is moved.
I'd suggest to move the whole structures several pixels up to allow immediate access to its terminal.
Backing up Mike CCM's comment on folder cleanup - We're using VIPM to turn modules into installed packages with the public API (only) exposed through the palettes. It'd be really handy to have all the public API VIs (and .ctls) in their own "public API" folder to make it quicker to create the palettes in VIPM (just get rid of everything expect the public API folder!
You could possibly go one stage further and sub-folder the "built in" API VIs (e.g. show panel, hide panel etc) and sub-folder "user created" API calls... but that may be a step further than absolutely necessary (I get why sticking close to a flat hierarchy is sensible too!)
Paul
Scripting API
Wouldn't it be great if we could hook into the scripting process of DQHM and, for example, add our own automation steps to the creation of new modules or new events? Something like the "post-build VI" feature of the application builder...
https://forums.ni.com/t5/Delacor-Toolkits-Discussions/Scripting-API/m-p/3655950
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
Sometimes it's very helpful to combine all three event types of the DQMH framework to one event type. Especially by using TestStand for automated testing.
In TestStand I want that an event is blocking and after finishing, the next step is called. But if I use a graphical user Interface (created with LabVIEW) for manuell testing to call the events, I don't want to wait for finishing because my user Interface is blocking too.
So for automated testing I need "Request and Wait for Reply" and for manuell testing I need the "Request", but I don't want to create two Events for the same functionality (redundant code).
Optionally I could add an broadcast Event too.
Discussion: https://forums.ni.com/t5/Delacor-Toolkits-Discussions/Combining-the-functionality-of-all-3-event-typ...
It would be great if there was a polymorphic VI which held all the public APIs and got modified after creating new public APIs.
This would speed up the process of accessing the APIs using quick-drop. So the polymorphic VI could be dropped and the right instance chosen easily.
DQMH Version Constant VI
In order to display or log the DQMH version number which any given application is built on, I pull it from a random DQMH VI by parsing its documentation tag:
_____ Based on Delacor QMH Project Template 4.0.0.41.
So far so good. But depending on what exactly I want to achieve with this, I cannot just randomly pull this information from any given DQMH VI. I can read the Delacor QMH Project Template version that the VI was created with, and I can read the Delacor QMH Palette version. I cannot read the version of Delacor QMH as it shows up in VI Package Manager (if I'm not mistaken).
Feature Request: A VI that gets installed with DQMH that returns the version number of the currently installed .vip. I guess it's quite easy to script one...
Strip HTML formatting from VI description for MHL subdiagram label
All said, I think.
Feature Request: Remove the <b> and </b> tags from the description text before writing it to the message case's subdiagram label.
Have a Create DQMH Helper Loop option in the DQMH menu
I think helper loops are used by enough people that having that done automagically would be a great feature for the DQMH toolkit.
Basically create the loop, the Wake Helper Loop event, the Sleep Helper Loop event, and then register the loop for those two and the Stop Module event for the module that the loop is placed within. The actions within the Timeout case would have the #CodeNeeded note. Possibly a #CodeRecommended note in the Sleep Helper Loop and Stop Module cases as well. Also event requests should be placed in a PrivateRequest folder in the project.
Discussion is located here: https://forums.ni.com/t5/Delacor-Toolkits-Discussions/Feature-request-Automate-the-Helper-Loop-creat...
Icon Overlay for Broadcast VIs
Sometimes when looking at a DQMH (main) VI's block diagram, I find it difficult to spot which VIs are just subVIs encapsulating functions, and which VIs are broadcasting and communicating data to the outside world. Our coding conventions now make a rule of manually changing the VI icon of broadcast VIs to carry a glyph symbolizing the broadcast character, as can be seen in the screenshot below:
(We dictate icon layouts and colors. The colored bar is green because this is a User Interface module. The colored square is used to distinguish multiple UI-related modules from each other. The broadcast glyph is then colored as the square is, but with inverted colors.)
Here's the glyph PNG that we put into LabVIEW's data folder, eg. C:\Users\admin\Documents\LabVIEW Data\Glyphs\
Feature Request: Change the VI icon of broadcast VIs during generation (automated scripting) so they are more easily distinguishable.
Edit: More details in my guest blog post on delacor.com/vi-scripting-add-glyph-to-vi-icon/.
Or even better, actually bold the specified text in the MHL subdiagram label. I like this idea.
Feature Request: Please add a new tool to convert "Request and Wait for Reply" Events to "Round Trip" Events. (Discussion is located here)
That would take a lot of click work off our hands.
Feature Request: Ability to see what modules or VI are set to read only when attempting to modify the a module. If there are multiple modules, it can be difficult to locate the offending vi.
See here for original post in forum.
Feature Request: Rename DQMH Event - Ability to edit description
When renaming an event, include a control to display the description of the event so that it can be edited and updated automatically.
Feature Request: Create New DQMH Event - Two Argument Windows for Req&Wait4Reply
Feature Request: New menu option: Save DQMH Module as Template
New menu item: Save DQMH Module as Template. This would allow the user to select a module and save it as a template. A dialog would appear prompting the user to select the DQMH module they would like to save as a template. This would then automatically create the xml file, and copy the module over to the LabVIEW Data folder, ready to be used as a template. Saves a lot of time and confusion with regard to setting up the xml file.
Buttons for newly created events in API Testers
When creating new requests, the first window that pops up is the block diagram of the API tester, where (99% of all times in my case) you need to add a button, and link the event case to that button.
Feature Request: When scripting the new event case in the DQMH_EVENT_TESTER event structure, also create a button and link the event case to that button.
Error tolerant "Module Did Init" Broadcast Vi
if i put some initialization code into the "Initialize" MHL-Case and there occurs an error, the Module Did Init Broadcast will not be send if the error wire is wired through.
That's why i have to modify the code to route the error around the broadcast-vi:
I like to have the error routing code integrated into the "Module Did Init" broadcast vi:
This would guaranty the message will be send always and makes the code in MHL case cleaner.
regards,
Thomas
Thomas did you see this discussion: https://forums.ni.com/t5/Delacor-Toolkits-Discussions/DQMH-Module-Did-Init-broadcast-event/td-p/3776...
Feature Request: Request and Wait for Reply: Make timeout an error bool input
Update the Request and Wait For Reply vi to have a boolean input titled "Make timeout an error". If set to true, the VI would generate an error from the timeout scenario, and hence avoiding the need to handle the timeout after every call of a Request and Wait For Reply.
I gotta say that we modify the Request and Wait for Reply most of the times to make the timeout an actual error out. I would actually prefer changing the behavior to always throw an error when the reply times out. See James' comment here.
API Tester and request VIs for cloneable modules
When creating new requests, DQMH 4.2 now not only creates the case in the API Tester but also creates a button and links it to that event case. For singleton modules, all done and dusted. For cloneables though, I still need to wire the module ID.
Feature request: When scripting a new request into the API Tester, connect the module ID wire coming from the shift register to the "Module ID" terminal of the new request VI.
Feature Request: Option to create a cloneable version of a singleton module
Bonus Feature: Option to create a singleton version of a cloneable module.
The benefit of such a feature would come from the fact that we have a number of internal team templates, and we often need to maintain update two of each ( a singleton version, and a cloneable version). The main reason we need to do this is because RT requires all modules to be cloneable, but Windows does not. So when we build up our internal team templates, we need to create two - a singleton for Windows and a cloneable for RT. But if we had such a feature we could simple code up a singleton, and then convert it (or save as) to a cloneable.
Chris, I'll pm you regarding the need for cloneables on RT (there isn't one).
OK, thanks Joerg.
Just to be clear though, this feature is not just about RT (although it was a big motivation for it). It could apply to non-RT modules.
Feature Request: Script the 'Status' string update code in the API Tester for new broadcast events
When I create a new Broadcast, here's what the new frame in the API Tester looks like:
I almost always end up adding the following code by hand (usually by copying it from another frame):
It seems to me that most of this code could be scripted. Maybe everything except the value of the first format string?
Feature Request: Ability to create several events that have the same payload at the same time.
In a recent project I had to create 15-20 "request and wait for reply" events, each of which had the same payloads. On my machine it takes 20-30 seconds to create each event, so not long enough to actually do anything, but long enough that I start to get annoyed.
Ideally I would like to be able to have a "create multiple" option, supply the event names (method open for discussion), select my payload stuff and click OK. I can then go and make myself a cuppa while it crunches away on all the scripting loveliness.
I believe that this could have saved me quite a lot of time in this last project, not to mention it's more efficient as I can do parallel tasks (like drink tea).
As an expanded option, I could see the benefit of being able to create all the events from an Excel type sheet. That way in an architecture meeting each event can be discussed and decided upon, diagrams drawn, spreadsheet created and then just loaded in and boom, done! BTW, I use the terms "Excel" and "spreadsheet" as examples, I hate both concepts but everyone knows what I mean.
Cheers,
Darren.
Feature Request: Option to not script the "todo" type labels when creating new events
After using DQMH for more than one project I imagine most people just immediately delete the labels describing what needs to be done in each case generated. While they are very useful the first few times, it would be handy if there was an ini token or a checkbox where you could turn off their creation.
Cheers,
Darren.
Feature request: Plugin framework / Automated packaging into ppl upon build
The current way to use DQMH with plugins (packing it into a ppl) is, unlike so many of the other nice features of DQMH, not a smooth automated process - and doing it means you lose access to many of the scripted features of DQMH.
It would be great if plugin architectures were handled by the toolkit itself - meaning we could use DQMH as it is all the way until we need to build the application, and then the DQMH toolkit would automatically take care of the steps required to convert the solution into one based on ppls ![]()
Feature Request: Add module description field to Add New DQMH Module window
When creating new modules, I'd like a way to add a description (like for a new event) to enforce good practices and allow automatic a future documentation tool to retrieve information.
Note: description could be added to module lvlib.
[EDIT]
[\EDIT]
Feature Request: Renaming of Module Template during creation
When creating a module template there should be an option to run the "rename DQMH module" process first, however instead of just renaming the original it should create a duplicate module with the new name.
Why?
Recently I created a new template from a "real" module (i.e. one I was actually using in the project) and then when I created a new module using the template it recreated the real module, along with all the events, SubVIs etc. I had added since creating the template. I assume this is something to do with the library file still being in memory/part of the project. I didn't specifically set out to create a template, which is what I should have done.
Hope that's in some way clear.
Cheers,
Darren.
Message Name in Error Handler for Message Handling Loop
Sometimes, the error cluster that feeds into the Delacor QMH Error Handler - Message Handling Loop.vi doesn't convey enough information to identify the origin of the error. For example, an Error "91 - Variant To Data in xyz.lvlib:Main.vi" does not tell me in which MHL case the variant to data operation failed. It would be nice to have the selector label of the MHL's case that the error occurred in.
Feature Request: Somehow (not sure what the best way would be) make the error handler include the last message's name (string) in the error broadcast.
A minor feature request / bug report running DQMH 4.2.1.46
When renaming a module should also rename the Test API.vi
I had a working module called Results that was a singleton and I decided that I really wanted a clonable version. So I used the rename module option and changed Results to _Results ready to create new new Results module, Did not intend to keep the singleton module I just wanted it for reference.
The rename nicely works I now have a _Results.lvlid in a new folder _Results all in my project but the tester VI is still called Test Results API.vi. this means when I go to create a new Results module the scripts fail with a error 7 file copy on the trying to create the new Test_results API.vi as there is already one in the project.
Took me only a few minutes to realize what the problem was and sort it, but it could catch others out.
cheers
Danny
When I need one of the reply payload values of a Request and Wait for Reply VI, I need to unbundle 100% of the time. What if the Request and Wait for Reply VI output the reply payload elements individually on the VI conpane so I don't need to unbundle? I often make this change manually to my Request and Wait for Reply VIs. And I never unbundle the error from the payload, since it's already merged into the error stream inside the VI. So I wouldn't expect that output to be on the conpane. But all the other payload parameters, you betcha!
