DIAdem
weird save block problem
Hi there,
i have a really weird problem. I load and start a dac in a loop via vbs, after measurement there is some calc done. 12-14 times that works fine without a problem, after this there were no channels created and no data saved.
If i restart diadem i can continue the measurements again, after 12-14 times it is the same again. Did i miss some settings, about rewriting channels in a group. The Script and the dac does the same in any loop.
Thanks for your helpful suggestions.
diademi
(3,971 Views)
Hi diademi,
I'm sorry, but without more detailed info I'm not really able to help you.
Which DIAdem revision are you using? Can you provide a scenario (with simulated DAC channels) to reproduce the problem?
Greetings
Walter
(3,925 Views)
Hi Walter,
i think, i solved the problem already. Sadly till today i had no chance for proof.
In my opinion the reason was, that the delay i used for setting the DC_Abort Variable in the DAC, was to short. The Save-Block i use, has a pre-trigger and sometimes, propably when the computer was on-load, the save block hadn´t enough time for saving anything. Is that possible.
diademi
(3,877 Views)
