DIAdem
waveform collect from lecroy
I'm just working on lecroy oscilloscope. I've to save waveform which is averaged by oscilloscope. Then I've few seconds delay and it will continue like this way. Then I've to integrate all graphs and have to save in pc.
I can do everything but my vi shows error  when I want to attach unbundle function in my vi and also i couldn't connect this function to read waveform vi. Pleae help me if anyone has some idea.I'm new in labview.
Best regards
Abdul
(3,899 Views)
Hello Abdul,
you are in the wrong forum here. Please write again in the LabVIEW forum:
http://forums.ni.com/t5/LabVIEW/bd-p/170
It would be good to add your VI with the errors. Then its easier to see, where the problem is.
Regards!
RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(3,879 Views)
Hi All,
I agree that the questions being asked are more for the LabVIEW forum, but note that there is a DataPlugin downloadable for free at www.ni.com/dataplugins that reads the data files that LeCroy scopes create natively, so you could read these data files into LabVIEW or DIAdem, if that should prove helpful in the future.
Brad Turpin
DIAdem Product Support Engineer
(3,863 Views)
